Twin Fuel pump wiring setup
Old Jan 19, 2011 | 04:13 PM
06_aspen_sti's Avatar
Question Twin Fuel pump wiring setup
Question about running twin fuel pumps. I have two, in tank Walbro 255 fuel pumps and I just want to know if I can split the single power/ground already there into two, to run both pumps or do I have to run another power and ground to the second pump. If so, what is the best way to do this?
Respectfully,
Patrick
Old Jan 19, 2011 | 09:51 PM
cewrx7r1's Avatar
Eye In The Sky
The stock fuel system wiring system has a lot of voltage drop do to use of small gauge wires, and also using a small grounding wiring going forward instead of using the chassis ground near the pump. For a single pump upgrade many run parallel wires to increase current flow and thus apply full voltage but still have the pump speed relay.
Since you have a high flow setup, the speed control relay might not be able to handle the increase of current. Thus many move/use the FP circuit opening relay near the pumps to switch on full battery/charger voltage to the pump/pumps. This requires total rewiring.
Old Jan 20, 2011 | 01:45 PM
JTurtonRX_7's Avatar
EFR IWG 8374
The search button works wonders, use it
https://www.rx7club.com/showthread.p...wire+fuel+pump
Old Jan 20, 2011 | 01:47 PM
EFR IWG 8374
http://www.reganrotaryracing.com/fddualfuelpumps.htm
Old Jan 20, 2011 | 03:13 PM
Thanks for the info. Helps out alot.
Originally Posted by JTurtonRX_7
Thank you for posting these two related threads. Sorry about the search.
Thank you for this thread as well
Queppa
Nov 18, 2024 03:47 AM
82streetracer
Aug 23, 2015 09:28 AM
