window weather stripping
Old Jan 18, 2011 | 08:30 PM
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
do I have to pull the front and rear windows to put in new weather stripping?
Old Jan 18, 2011 | 10:06 PM
Sephek's Avatar
Are you talking about the hatch and windshield weather stripping?
If you want a good seal between the two then yes, but it most likely will chip, crack or break.
Old Jan 18, 2011 | 10:13 PM
yes the hatch and windshield. its already sealed very well I just want it to look cosmetically correct. if thats the case do I need to have the glass removed.
Old Jan 19, 2011 | 04:47 PM
unvmyrx7's Avatar
yes, the windshield and rear hatch glass has to be removed. the weather stripping is fitted around the windshield then held in place with urethane. the rear hatch is a little different. if you can remove enough of the oem urethane, you can glue the new moulding in place.
Old Mar 16, 2011 | 04:04 AM
okay so I'm kind of nervous about having the glass pulled the local company said that there is a possibility it will break and that they can't get new glass for the car. so I called mazda and they said the windshield and back glass are no longer available so getting new glass looks unlikely if they break it.
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
turbojeff
Oct 5, 2015 10:50 AM
