pics - 1/2 a$$ antenna repair - will this work?
Old Jul 4, 2002 | 07:31 PM
vaughnc's Avatar
knowledge junkie
Will just replacing the antenna mast work like this guy claims?
Anyone every try repairing the power antenna like this?
The new "black" antenna mask I put on the TII looks SWEET - but $90 - ouch!!!
A $25 repair on the convertible would be great instead of buying a whole new antenna
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1841586058
"QUOTE":
This HIGH QUALITY MAST Fits the following: (( MAZDA RX-7 1986-1992 )). THIS MAST COMES WITH EASY TO FOLLOW INSTALLATION INSTRUCTIONS AND YOU CAN DO IT YOURSELF IN A MATTER OF MINUTES!! If your antenna motor runs (clicks) but the mast doesn't go up or down, or your mast is "BENT", this is the part that is needed to repair your antenna.
Old Jul 4, 2002 | 08:21 PM
Six Rotors's Avatar
It depends what is wrong with your antenna.If it is just a broken cord it will work.In some cases though the relay on the antenna fails in which case you must replace it.Every once in a while I visit wrecking yards and pick up power antennae--in about 50% of cases the relay is failed--but it is cheaper than buying new ones,By the way you can buy a new antenna mast at Mazda for about $35 Can(or $23.50 US)
Old Jul 4, 2002 | 08:25 PM
vaughnc's Avatar
knowledge junkie
Yeah I'm assuming if the motor's "wirring" then the relay is fine and I just need to replace the mast.
Cool, I'll dissassemble mine and get the replacement from mazda.
Old Jul 5, 2002 | 12:32 AM
Sniper_X's Avatar
now this, i know alot about...
Replacing the mast is MUCH easier than replaceign the antenna mech.
Just make sure that there is no remaining antenna gear rod left in the motor.
you should remove the motor, then remove the one screw holding the cap on the spool and check to make sure its all clear in there.
then re install the mech minus the top screw ring and sleeve.
Place the sleeve over the new mast.
Turn on the radio.
the antenna motor will go "up"
Push the new mast into the motor as far as you can, wiggling it to make sure.
then have someone turn OFF the radio and feed the antenna into the motor. CAREFULLY.
it will go down flush.
screw on the ring. tighten everything and turn the radiop back on.
see- all fixed!
Old Jul 5, 2002 | 12:33 AM
Sniper_X's Avatar
oh, and vaughn...
I get the black button masts for $20.
I even have one here,
Old Jul 5, 2002 | 01:35 AM
vaughnc's Avatar
knowledge junkie
must be a black universal one then ?? Where did you find that one?
Old Jul 5, 2002 | 01:37 AM
Sniper_X's Avatar
no its a black MAZDA one, from my dealer acct w/mazda.
Monsterbox
Jul 29, 2022 10:48 PM
Th0m4s
Feb 26, 2019 02:04 AM
befarrer
Aug 14, 2015 04:18 PM
