RPF1 Center caps
Old Dec 24, 2010 | 04:19 PM
Warpaint_88's Avatar
Darkside Performance
RPF1 Center caps
Anyone know any sources for a good center cap other than the commonly found RPF1 racing center caps? I have the same ones that are in my avatar already but looking for other options like a plain matching silver to switch it up once in a while.
Old Dec 24, 2010 | 04:52 PM
MR_Rick's Avatar
Planning my come back
My NTO3s came with an extra set of center cap. If you want to see if they fit you are welcome to come by and see.
http://www.tirerack.com/images/wheel...ge/NT03CAP.jpg
Old Dec 24, 2010 | 04:56 PM
I would love too! give me 6 months to come back from this deployment i left on two weeks ago
Old Dec 24, 2010 | 04:57 PM
Was also going to ask you if you rolled your fenders? I think you said somewhere you did in the front. If that was you where did you get it done and what did it run you?
Old Dec 24, 2010 | 05:16 PM
ALPSTA's Avatar
Mission Impossible
I've seen some people using centre caps that are for Hondas if I'm not mistaken. I'm on mobile so I can't post links right now but google keywords like rpf1 center caps s2000 s2k honda etc and it will come up. The ones I've seen were silver and flat, not sticking out like enkei ones.
Old Dec 24, 2010 | 05:31 PM
MR_Rick's Avatar
Now that I look at it I don't think my center caps will fit. My screw in vs the RPF1 are snap on. I do know how to modify them to make them flush.
I got my front rolled at Stock and Modified for $75 a fender.
Old Dec 24, 2010 | 05:32 PM
That is not a bad deal there good sir.... I will have to look them up when I get home. Supposedly my 255/35's on a 18x9.5+45 will fit but im not 100% sure it will wont rub at all on our local roads.
Old Dec 24, 2010 | 05:54 PM
MR_Rick's Avatar
Well I run 18x9.5 40mm offset with 265s and they rubbed a little. I'm pretty sure you be fine with that fitment.
Edit: 40mm offset
Old Dec 24, 2010 | 05:58 PM
freaking awesome
Old Dec 24, 2010 | 06:01 PM
MR_Rick's Avatar
oops make that 40mm offset
Old Dec 24, 2010 | 06:15 PM
Well with a 45mm I should be even safer right? or wrong... either way im going 255's up front. Should be safe!
Old Dec 24, 2010 | 08:13 PM
MR_Rick's Avatar
You should be fine
Old Dec 25, 2010 | 01:56 PM
silverTRD's Avatar
Time or Money, Pick one
look at the fd wheel spreadsheet, you should be fine.
Old Dec 25, 2010 | 03:09 PM
I cant look at it, Im on military computers and cant download anything. Or else i would have already.
Old Dec 25, 2010 | 10:33 PM
books's Avatar
centercap...
http://www.nsxprime.com/forums/showthread.php?t=117429
Old Dec 26, 2010 | 07:24 AM
Good stuff books, I couldnt quite figure out though. Would those center caps come with the Acura emblem or is that just a sticker that can be removed, I read in a post on there that the emblems from a honda center cap can be removed but nothing for the acura.
