Fans wiring issue
Old Dec 23, 2010 | 03:22 AM
ShiftRX7's Avatar
Fans wiring issue
After having put my fans on and off several times, i realized that i might be messing up with the wires color matching on the power plugs...i have come to this conclusion cos my A/C button is not triggering the fan speed increase as it should; ive checked the relay and it's working fine so im assuming it could be that i inverted 2 wires while changing the connectors.
Since im not able to reconcile the colors with those on the wiring diagram, can someone please post/send me a picture of how his stock connectors look like?
Thanks for your help, it's much appreciated.
Old Jan 3, 2011 | 01:06 PM
ohioredrx7's Avatar
Bump...I'm in the same boat. Could someone please help us out?
Connector #1:
Black -> ??
Blue/Orange -> ??
Yellow/White -> ??
Red/Yellow -> ??
Connector #2:
Black -> ??
Blue/Orange -> ??
Yellow/White -> ??
White -> ??
Old Jan 3, 2011 | 09:02 PM
Sephek's Avatar
I don't if this is of any help but here's a diagram of the cooling fan circuit, do you need a picture of the actual fan connectors?
Old Jan 4, 2011 | 09:11 AM
ShiftRX7's Avatar
Thanks for the help...so this actually shows which cable is which up to the fan connector...easier to read with the color (even though i was kinda able to figure it out from the black and white sheet that's in the wiring manual).
Problem is, once you get to the fan connectors the one coming from the fans have different colors...so i pic of the actual ones could be able to help! Not sure fans wires are not the same color as those coming from the rest of the circuit...
streetlegal?
Mar 17, 2022 02:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
PhillyFC
Aug 21, 2015 06:36 PM
Wicked93gs
Aug 17, 2015 12:14 PM
