Won't Accelerate - Computer Problems?
Old Dec 10, 2010 | 11:49 PM
dagoof's Avatar
ID Won't Accelerate - Computer Problems?
My car had been sitting for a couple of weeks, and a minute or two after I started it up the check engine light came on.
Obviously, I'm going to have to pull the codes and try to find out what's going on, but I figured I'd throw this out there to see if anyone can help guide me in the right direction.
The car seems to run fine until the check engine light comes on, and then it won't allow you to accelerate at all. Is this limp mode or something?
You can't get into boost at all, and if you try to accelerate too much it just stumbles all over itself and gargles at the tailpipe. The engine will rev just fine when parked, but not at all when it has a load.
The strange thing is, that it takes a few moments for the check engine light to come on. If you start the car up and take off immediately, the problem won't start as long as you can stay on it. It only starts when you come back down to cruising RPM or let it idle for a few moments.
If anyone has any advice on which way to point me, I'd appreciate it.
I should mention that my seven is all stock with 67K on it.
Old Dec 11, 2010 | 01:35 AM
FD3S2005's Avatar
SideWayZ The Only Way
i had some issue one time with it stumbling and didnt want to accelerate, and i got a check engine light like a year ago it happened, seemed to be one of my secondary injectors failed. but it drives normal aslong as you didnt go over a certain rpm
Old Dec 11, 2010 | 01:38 AM
cptpain's Avatar
Torqueless Wonder
check your hose to the map sensor, it my have blown off at some point, always check the most simplest explanation
Old Dec 11, 2010 | 06:12 AM
1QWIK7's Avatar
White chicks > *
Best thing to do right now is just pull the code. Otherwise you'll just go crazy. Problems like these on our cars could be ANYTHING.
Old Dec 13, 2010 | 10:16 AM
dagoof's Avatar
Well, I pulled the codes yesterday morning, and I got a 27 and 50, which is double throttle and metering oil pump.
Then I got to thinking that the engine should probably be warm before I check the codes, so I took it out for a quick drive, and surprisingly, my car ran fine. I ran several errands, came back, cleared the codes and checked again, and all I got was the 50 code (double throttle).
So, I have to assume that the main problem had to to with the metering oil pump. (code 27) I think I've read somewhere that the MOP code will put the car into "limp mode", so that would make sense.
Unfortunately, after tinkering around for an hour or two, I started my car back up, and the check engine light and both codes were back.
So, I guess, I'm going to have to start checking my wiring to the MOP. It looks like it's going to be easiest to get to from underneath. Am I right?
Old Dec 13, 2010 | 01:04 PM
Sgtblue's Avatar
Urban Combat Vet
Originally Posted by dagoof
.....So, I guess, I'm going to have to start checking my wiring to the MOP. It looks like it's going to be easiest to get to from underneath. Am I right?
Yes, 27, or the other codes (IIRC 3 total) related to the MOP/OMP will put you in limp. As for fixing it, I did it from underneath...
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/changing-oil-metering-pump-omp-while-car-my-how-675341/
Mine was a transient initially too. But it came back and stayed.
Old Dec 13, 2010 | 01:52 PM
dagoof's Avatar
Is it normal that when I can start the car and take off immediately, I don't get any check engine light or limp mode?
It only falls back into check engine / limp mode after I've slowed down to idle/cruse speed.
As long as the engine is under load, everything runs fine.
Old Dec 13, 2010 | 03:53 PM
Sgtblue's Avatar
Urban Combat Vet
Normal? I don't know. You might be (hopefully) suffering from some weird continuity issue that's easy to fix. But as I said earlier, mine was intermittent at first too. I'd re-set and for brief periods, maybe as long as a day or two, everything would be good. But eventually it came on and stayed...even after clearing the codes it would return almost as soon as the car started. Though it didn't seem to have anything to do with slowing down or idling. Mine first appeared after a hard WOT run onto the freeway.
Old Dec 14, 2010 | 08:02 PM
dagoof's Avatar
So, I guess my next question is,
If the MOP is bad, and I don't want to shell you the dough and time to fix it at the moment, then how do I bypass the electronics?
I've been pre-mixing anyways, so couldn't I do a hot-wire job and get my car back on the road for the time being?
I know I've seen guys on here talk about using a resistor to fool the computer and not get sent to limp mode. Can someone tell the specifics of how to do this?
Old Dec 15, 2010 | 09:44 AM
Sgtblue's Avatar
Urban Combat Vet
Don't know how you would "fool" the ECU. Probably a much better alternative is to move to a PFC. If you can't do that right now, a decent used OMP isn't much. While not a walk in the park, it can be changed without much overall cost.
Old Jan 4, 2011 | 09:49 AM
dagoof's Avatar
Anybody got a used OMP?
Old Jan 4, 2011 | 10:17 AM
jamespond24's Avatar
Me I got afew.
Old Jan 4, 2011 | 08:03 PM
dagoof's Avatar
Originally Posted by jamespond24
Me I got afew.
I'll send you a PM
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
