condensation in tailights
Old Jul 2, 2002 | 03:46 PM
cover8's Avatar
have taken apart light to check for condensation leaks..redid the silicone...what gives? do I need to place a drain hole?
thanks
Old Jul 2, 2002 | 03:56 PM
tfhuth's Avatar
Mines tight, no water. Did you search on this?? If this is a common problem I'm sure someone has posted it before. Tom
Old Jul 2, 2002 | 05:28 PM
rx7even's Avatar
There's a little vent hole already in the back. Attached to it is a U shaped rubber hose. Pull that off and check to see if it is clogged. Little things like to gather in there sometimes.
Old Jul 3, 2002 | 09:21 AM
cover8's Avatar
thank you rx7even for your positive feedback. 90% of my time on this forum is spent on search. thougth someone might have a quick fix. this one seems very simple...
thank you
