help please car doesnt start
Old Jul 2, 2002 | 01:51 PM
T88Rx7's Avatar
the electric goes on but when i want to crank the motor nothing happens. it doesnt even turn over i dont think its the fuses
Old Jul 2, 2002 | 01:59 PM
DK's Avatar
DK
40k worth of fail
Uhhhhhh ... starter? Take it off and jump it with a battery/charger and a screwdriver or stout wire and see if it fires.
Do you really have a T-88 yet you don't suspect the starter first if nothing is turning over?
Old Jul 2, 2002 | 02:34 PM
ttpowerd's Avatar
HARRRRRRRRR
could have flooded the motor....
could be the starter....
could be the fuses....
if you can push it or roll it a little then just pop the clutch and see if it will start. If not then it is your starter. Otherwise it is always a good idea to clean out the carbon deposits with the ATF trick and it will also help if your motor is flooded. Other than that check the fuses.
Old Jul 2, 2002 | 02:41 PM
DK's Avatar
DK
40k worth of fail
He said it's not turning over.
Old Jul 2, 2002 | 02:42 PM
ttpowerd's Avatar
HARRRRRRRRR
When I flooded my motor it did not turn over (or I don't remember it turning over).
Old Jul 2, 2002 | 02:56 PM
mike 25's Avatar
check the clutch switch
Kyo
Apr 13, 2019 09:24 AM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
ashleymiche
Aug 14, 2015 12:59 PM
