Fuel Pump, 3k?
I know it's not the ecu, but one member had the idea that it was because the fuel pump ran on two stages, and the problem occured when switched from stage one to two (I think). I want to know if anyone running a Cosmo pump, or a Supra pump, or the RP upgrade is still experiencing the problem. Of course, they had to have had the problem in the frist place.
False...
I am still very new so take this with a grain of salt. I cannot tell you if it worked for me. Haven't had this problem. Hey... Try a search... I love that damn button!
Adding extra ground to the battery will not necessarily fix your 3k hesitation. Tried this with stock ecu and it didn't fix it. M2 Stage 3 ecu still gives 3k hesitation though it isn't as noticeable. Hear the same things with Pettits unlimited.
I got the PFC and my 3k hesitation is gone.
That was my situation anyway. Like everything else on this car, its different for everybody.
Trending Topics
http://www.scuderiaciriani.com/
And yes, the cleaned ground and extra ground do help with the 3k hesitation.
Yes, a replacement ECU (not stock remapped/piggyback) does remove the 3k hesitation completely. In my 94 I still had a slight hesitation but with the adding of grounds it got a bit better. With the PowerFC it no longer exists in my car, as well as many other people with the PowerFC.
I'm glad upgrading the ECU worked for you, but that doesn't necessarily mean that the ECU fixes the 3K hesitation.
Take a look at this thread, this may be a possible solution.
https://www.rx7club.com/forum/showth...threadid=91818
I knew this thread would get a lot of opinions. Most of my grounds are tight. I do have one loose ground from the body to the cat/catback joint. And, it is usually worse when cold. I added an EFI PMC and the problem is still there. I am runnig it as a piggyback, not as a standalone though.
The thread linked by RxJjang, started by DamonB is the reason I started this thread. I wanted to know is after upgrading the pump if anyone still had the problem???
Originally posted by Mahjik
That's not entirely true. Many people do not have the 3K hesitation even with the stock ECU. Even so, the PowerFC may have just made the hesitation less enough that you don't notice it but it's still there.
There is NO hesitation at 3k, not just un-noticeable.
I disagree. All of the people that I have talked with, that have purchased a Power FC has stated that they no longer have any hesitation at 3k.
How do you account for the people with stock ECU's and no hesitation?
I would attribute it to the grounds for the cars that have the stock ECU. The better the grounds the less of a hesitation.
2) most past 'fixes' were temporary, or did not work.
3) afaik, the pfc fixed every case of hick-up.
conclusion: stock ecu is the problem. it may well be true that a 'bad' ecu will work better in another car, due to lack of robustness in the oem ecu set-up. The pfc fixes the problem in all cases.
Originally posted by KevinK2
1) some/many stock ecu's have 3k hick-up.
The fact is that not all FD's exhibit the 3k hesitation, at least enough to be noticeable. This includes stock ECU FD's, so by theory, that rules out the problem being with the programming in the stock ECU.
Like I said before, I don't believe the ECU is the problem. I believe that in rewiring for a new ECU that the problem is reduced (same is re-grounding or adding new grounds), however I'm more incline to believe that the hesitation is caused by the fuel pump as theorized in the other thread.
So how would you explain that the addition of a larger fuel pump, from the cosmo (brand new) still allowed the 3k hesitation in my 93? Then I added that fuel pump to my 94 and no change in hesitation.
There is no rewiring with the Power FC, it plugs directly into the stock harness. There was a study done on the injectory duty cycle where it was noted that it may be a problem with the secondaries and how they come online or not, which is controlled by the ECU. Under light throttle even when cold, the hesitation with a stock ECU is slight to none, under more moderate acceleration the switching to the secondaries may be what causes the hesitation. I believe that this info is on www.scuderiaciriani.com .
So how would you explain that the addition of a larger fuel pump, from the cosmo (brand new) still allowed the 3k hesitation in my 93? Then I added that fuel pump to my 94 and no hesitation.
There is no rewiring with the Power FC, it plugs directly into the stock harness. There was a study done on the injectory duty cycle where it was noted that it may be a problem with the secondaries coming online or not, which is controlled by the ECU.
If you read here:
http://www.scuderiaciriani.com/rx7/3k_hesitation.html
There were a lot of things tested, but everyone seems to agree that the FD's didn't roll off the assembly line with the 3k hesitation (at least not noticeable).
If you look in that other thread posted about the fuel pump, it seems it's more of an electrical thing rather than a pump thing. Which would seem more plausible since extra grounding or re-grounding has fixed the problem for some people.
Then again, what some people may be calling "3k hesitation" may in actuality be different which would also account for the wide variety of solutions.
My point is that there are cars without a "3k hesitation" which are using the stock ECU, therefore the theory of the stock ECU being the problem is invalid. Not saying that the PowerFC won't reduce the effect or make it go away, but that it may be inadvertently fixing the problem.
i dont mean rain on any parades, but i actually tested this on my car.
1. the hesitation is always at the same rpm.
2. the fuel pump switch over is not, it is load dependent.
3. cleaning (sanding and applying distributor grease) fixed the problem on my car.
4. it came back about a year later
5. i have had 2 different pfc's in my car, they both did not have the hesitition, and the stock ecu did
mike
mike
As for the PowerFC install, I assumed there was some wire cutting and splicing needed for the install. I don't have one, so it was just assumptions.
ChrisRX8PR
Oct 18, 2015 04:01 PM
