Car won't start
Old Jul 1, 2002 | 05:36 PM
Jahoo88's Avatar
Car won't start
Ok, i hooked everything back up after my clutch job and it wont start now.
It clicks but i think its the fuel pump turning on, not the starter.
Theres a ground wire on the top of the tranny right by the bellhousing, where does this wire go? It came out when i pulled the tranny and i cant find where it goes now.
I also took the P/S pump out, could the lack of the ps wiring be causing it?
And how does the starter work? it seems to lose voltage when the key is turned is this what its supposed to do?
Old Jul 1, 2002 | 05:56 PM
Silkworm's Avatar
Has been.. hangin' around
Ground wire goes to the body of the car, under one of the nuts that holds the vacuum hardline to the brake booster.
That ground wire is particularly important, IIRC, get that on ASAP. Then try it again.
PaulC
Old Jul 1, 2002 | 07:54 PM
Jahoo88's Avatar
ok, the ground wire is attached to a bolt on the tranny and it has a black connector on the other end
Old Jul 1, 2002 | 08:09 PM
DuX's Avatar
DuX
well, does it work now?
Old Jul 1, 2002 | 10:12 PM
Jahoo88's Avatar
No no, the wire was already attached on the tranny bolt(near bellhousing), i just cant finde where the black connector on the other end went.
Old Jul 1, 2002 | 11:05 PM
seveninphilly's Avatar
on the road to insanity
I believe it goes near the wiper motor there should be a copper/brass male connecter it goes to, on the fire wall
Old Jul 2, 2002 | 12:52 PM
Jahoo88's Avatar
thank you guys so much, i found the male connector under the wiper motor and she started!!!! Thanks again this forum is a life saver
alphawolff
Nov 17, 2015 05:57 PM
torky007
Aug 17, 2015 05:14 PM
