Replacement Antennae
Old Jul 1, 2002 | 01:30 PM
Rxmfn7's Avatar
Do a barrel roll!
My power antennae stopped working, and I was looking into getting a aftermarket replacement. Does anyone know if i can, and where I could get one of those small rubber ones, that are only like 6inches long. I hear they get better reception, plus there smaller, and probably alot cheaper than getting a replacement stock one. Just wondered if anyone had one, or knew where I could get one? Thanks
Old Jul 1, 2002 | 03:40 PM
Rxmfn7's Avatar
Do a barrel roll!
I think the small black ones were called Fubos or something?
Old Jul 1, 2002 | 03:43 PM
RexRyder's Avatar
check ebay, and ebaystores. search for RX7, or Mazdaspeed on both, I remember seeing one there. Your talking bout the small black Euro antenna that goes on ur rear hatch on the center rite?
Old Jul 1, 2002 | 04:05 PM
10TH_ANNIV_T2's Avatar
Harada and Hirschman used to make direct fit replacements. I don't know if they still do or not, but try Crutchfield if the eBay route doesn't work for you.
Greg O.
Old Jul 1, 2002 | 04:17 PM
Rxmfn7's Avatar
Do a barrel roll!
RexRyder: Yes the small black euro antenna, but I want it where the stock one is, not in the center of the hatch.
10TH_ANNIV_T2: Thanks, Ill try that.
Old Jul 1, 2002 | 05:15 PM
Audiofight's Avatar
Go to RadioShack. I got one from them for about $8.00.
They clearanced their car audio equipment a while back and I picked up a new power antennae for $19.99. I had to put a power one in b/c I put the Turbo spoiler on my car.
It is your call, if they still have either in stock. If your local R.S. doesn't have one, drop me a line and I will check the 4 near me.
The reception really didn't get noticably better, but I had good reception to begin with.
Old Jul 2, 2002 | 07:31 PM
Rxmfn7's Avatar
Do a barrel roll!
Just an update. I found one on Mazdatrix's website, just in case anyone else was interested. It was $20.
Old Jul 3, 2002 | 09:05 AM
If you meant the antenna mast, yes those are much more reasonable. I thought you were after a complete replacement.
Regarding a short (6") antenna's performance, it isn't going to be any better than the windshield antenna if you have one. Optimal antenna length for the FM frequency range is something like 30". I can dig up the exact details, but basically no amount of electronic trickery can compensate for not having the mast lenght correct for the intended frequency band. Using (we used to call them rubber duckies) those black, 12", flexible antenna's is a big compromise unless you are very close to the broadcast source. If you are, then you may not notice a difference.
Greg O.
Old Jul 3, 2002 | 09:10 AM
There is a guy that auctions off total replacement power antennaes on ebay for 46.95 but no one ever bids on them, at least not that I've seen.
t-von
Sep 10, 2015 01:56 PM
BLK 93
11
Sep 9, 2015 10:56 AM
Frox
Sep 8, 2015 08:36 AM
Enzo1944
Sep 6, 2015 08:57 AM
