What does this part do?
Old Jul 1, 2002 | 01:26 PM
RX-8's Avatar
I got my car back from Mazda and it runs like crap. Had a new engine put in. The blue connector in the picture is disconected (yellow arrow) and not all the vaccume lines are covered with hoses (only one that I can notice).
1st What does the blue connector do.
2nd Are all the vaccume lines supposed to be covered with hoses?
Old Jul 1, 2002 | 01:29 PM
rynberg's Avatar
1. The blue connector is not used on 5-speeds.
2. Your question is not clear.
None of us on the forum would trust a Mazda dealer to correctly re-install an engine and turbo control system. If things are incorrect, I would take the car to KD Rotary or PFS and try to get Mazda to cover it since they can't do it right themselves. Good luck.
RX-8's Avatar
opps here is an example picture of what I am talking about (this is not my car). the yellow arrow is pointing to the blue connector.
Old Jul 1, 2002 | 01:33 PM
RX-8's Avatar
keep forgeting the picture.........
Old Jul 1, 2002 | 01:37 PM
c00lduke's Avatar
pretty sure thats is for electronic EGR's
Old Jul 1, 2002 | 02:43 PM
RX-8's Avatar
I can't seem to find the other end of the connector. Does anyone know where the other half is located or connected to? And would this affect the way my car runs drastically? Please help.
Old Jul 1, 2002 | 04:21 PM
DamonB's Avatar
Like rynberg said; the blue connector is unused. There is nothing to plug it into.
Old Jul 1, 2002 | 04:34 PM
i know one of the vacum lines is only used on auto's, and i havnt found a unused connector. what exactly is your car doing?
Old Jul 1, 2002 | 06:32 PM
r_ed_line53's Avatar
Cool Two questions!
One - what year is your car?
Two - Is this a rebuilt motor or a j-spec?
It looks like you are missing two hard pipe vacuum lines that come from your air control valve. If you look to the left of that connector there's two hard pipe vacuum lines coming straight up. Those two connect to your air control valve, directly above it, but there's no connectors from the air control's, that I see. Do a search on vacuum diagrams. Good luck!
see ya,
car 53
Old Jul 1, 2002 | 06:42 PM
turbojeff's Avatar
Do it right, do it once
There should be a solenoid on top of the ACV. I see the plug but no solenoid. No second turbo without that.
The Blue connector is not for automatics, it is for Cal 93 or 94 EGR valve. Leave unconnected on other cars. Doesn't affect the way ANY of the cars run.
Jeff
Old Jul 1, 2002 | 06:50 PM
RX-8's Avatar
Thanks guys. My car doesn't accelerate smothly, it stumbles and hisses. I am on a buget Rikki. We should get together...see what can be worked out
Old Jul 1, 2002 | 07:56 PM
JONSKI's Avatar
5yr member, joined 2001
Do the simplification and get rid of as much rubber as you can. The rubber hoses get hard and are breakable in less than a year. My hoses were changed about seven months ago and the night before last I snapped both the nipples off of my turbo pre-contol solenoid. DOH! How much does that thing cost? Anyways, you also might want to consider the turbo simplification while you're at it.
Old Jul 1, 2002 | 07:57 PM
RX-8's Avatar
Thanks for the info Rikki But that **** looks to scarey for me. Guess I'll just give Peter a call on monday. Peace
Old Jul 1, 2002 | 08:00 PM
JONSKI's Avatar
Don't let it scare you. It's more tedious than confusing. I'm finding that out right now. This shouldn't be scary at all: http://www.rx7turboturbo.com/robrobi...lification.htm
Old Jul 1, 2002 | 08:08 PM
toecutter's Avatar
I know how you feel my car never ran right after mazda put in a reman engine.
I didnt have a boost gauge at the time so I couldnt tell how bad it really was. After spending 6 months trying to quick fix the problem I finally pulled the UIB and did the job right.
Now I remember why I bought this car.
Its really not that big of a job if you take your time and use the diagram.
Old Jul 1, 2002 | 08:23 PM
RX-8's Avatar
Thanks guys. Your boosting my confidence Maybe I'll take a stabb at it. I know what you mean toecutter. I take my car to the dealer for a new engine and it runs worse!! I've actually forgoten why I bought the car with all these problems but I am trying to hang tough.
Old Jul 1, 2002 | 09:05 PM
JONSKI's Avatar
Persistance and patience are key!
Heedlessone
288
Sep 16, 2018 07:22 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
