Flywheel
Old Oct 23, 2010 | 04:09 PM
jdr821's Avatar
Flywheel
Hi guys. Which flywheel you guys use? I'll be using a turbo2 transmission. Thanks in advance.
Old Oct 23, 2010 | 04:22 PM
j9fd3s's Avatar
Community Builder
its pretty easy. the 20b ONLY came automatic, so remove the flexplate, and bolt on the aftermarket flywheel of your choice
Old Oct 23, 2010 | 04:59 PM
hIGGI's Avatar
OS giken twinplate which i just removed from my previous 13BT setup
Old Oct 23, 2010 | 10:10 PM
Evil Aviator's Avatar
Rotorhead
Mine has an NA-sized Mazda Comp Billington 4-lb flywheel, modified 20B counterweight, and Quarter Master TII-spline 5.5" 2-disk Pro Series clutch pack mated to a TII transmission that was modified to accept both TII and NA sized flywheels. The effect would be similar to what hIGGI listed above, which would be suited well for road racing.
LongDuck
Oct 7, 2015 08:12 PM
