Will I Rub Thread?
Old Sep 30, 2010 | 03:42 PM
hkguy783's Avatar
Will I Rub Thread?
hey there... i been on this forum for a little bit less then a month now, and i been noticing there is a lack for a post for "Will I Fit/Rub" thread!!! Where in this post members on the forum will be able to ask question specificly about would their tire or wheel fit on their car with out rubbing or about the fitment! And other members with high knowledge or guru can help out other newbies.... LIKE MYSELF
Originally Posted by 9thgencorolla.com
Post your question regarding offset or if a rim will fit and what not here.
Be sure to include the rim spec and suspension system.
ie. Will I rub with 17x7 with offset +40mm on stock suspension.
*Tire sizing
Link if possible
http://www.9thgencorolla.com/forum/s....php?p=1295483
i will start first
will i rub with 19x8 +48. 5x114.3 on stock fd suspension
and what size tires should i put on it? would 19's be too much?
http://sfbay.craigslist.org/sfc/pts/1979360032.html
Old Sep 30, 2010 | 07:21 PM
Nice wheels, but I wouldn't recommend running 19s on an FD (although it's been done).
The offset, width, and bolt pattern are all ok. You'd have to check the centerbore size (FD is 67mm).
RX7-RR
Jun 10, 2018 11:40 AM
risingsunroof82
22
Sep 22, 2015 01:20 PM
MikeTee55
Sep 8, 2015 08:05 PM
