engine assembly pics (needed)
Old Jun 29, 2002 | 05:52 PM
CYM TKT's Avatar
hey, your car is on fire!
hey guys, I am in desperate need of pics showing how the accesories, turbos, etc fit onto the 13B-REW. I searched and found nothing. any pics you have would help me out.
maybe these pics would be in the shop manual, but I dont know because my friend has it. we are putting the engine back into my R1 and we just want to make sure we do everything right. thanks a lot.
Old Jun 29, 2002 | 05:53 PM
CYM TKT's Avatar
if there is a video that shows how to do this, can somebody send me a link to where I can buy it. i need it by this coming weds.
Old Jun 29, 2002 | 07:46 PM
turbojeff's Avatar
Do it right, do it once
I've got some assembly pics showing the installation of everything on top of the , unfortunately I can't send them right now.
Basically I'll give you an assembly order rundown of some major components.
First thing. Assuming the water pump is on.
Install lower intake manifold, remove ACV.
Oil metering nozzles and lines. The lines wrap around the water pump. Install the oil metering pump, wires route with the oil lines to the left side (ref from driver seat). Wiring for the OMP is fixed to the front engine lifting hook.
Install injectors, there is a little metal bracket that is bolted to the front bolt of the primary injectors, a branch of the main harness goes under this, not the oil metering lines.
Install main wiring harness. INstall complete solenoid rack with the the steel fuel lines.
Install oil neck.
INstall coils. Route the smaller wiring harness on the left side of the .
INstall turbos.
Install oil cooler lines on the left side of the .
Install PS and a/c pump (if they are off the car).
Install the vacuum tank that fits down by the a/c and PS pumps.
Route all the lines that travel from WG and PC solenoid down to the turbos.
Install airpump
INstall alternator.
I know it isn't a video but it might get you started.
Jeff
Old Jun 29, 2002 | 08:17 PM
video
There is a video out there, by atkins..go to their website www.atkinsrotary.com i believe its like 29 bucks or so
Old Jun 29, 2002 | 10:26 PM
CYM TKT's Avatar
thanks for the info. could you email me the pics at stratd@rpi.edu . thanks a lot
