FD Alternator conversion question
Old Sep 4, 2010 | 08:45 PM
alemmons's Avatar
89 GXL Turbo
Veteran: Marine Corp
Anyone know what the shaft diameter is on the FD alternator? I am getting an FD alternator to swap into my FC. I won't have a lot of time when I get my alternator so I am hoping to have the hole bored out on my double belt pulley before I get the alternator so it will be ready to go when I get the alternator.
Old Sep 4, 2010 | 08:48 PM
RotaryEvolution's Avatar
Sharp Claws
17mm
Old Sep 4, 2010 | 10:38 PM
Howru's Avatar
I
Another FD alternator swap question: do you re-use the s4/s5 spacer where it mounts onto the water pump housing, or just put it in and tighten?
Old Sep 4, 2010 | 10:43 PM
misterstyx69's Avatar
Retired Moderator, RIP
you use the stock spacer Howru..Put it at the back,between the Pump housing and the "rear Ear" of the alternator.
Old Sep 4, 2010 | 10:52 PM
Howru's Avatar
I
Got loads of info for wiring, but not about that spacer. Thanks!
Old Sep 4, 2010 | 10:55 PM
Japan2LA's Avatar
Why not just get the SPECIAL pulley made specifically for this upgrade?
Link:
https://www.rx7club.com/2nd-generation-rx-7-1986-1992-parts-194/brand-new-dual-belt-pulley-fd3s-100amp-alternator-upgrade-860869/
Old Sep 5, 2010 | 01:10 AM
alemmons's Avatar
89 GXL Turbo
I would if I didn't already have the Banzai non-underdrive dual pulley
Old Sep 9, 2010 | 04:59 PM
alemmons's Avatar
89 GXL Turbo
What do you use for a spacer to run the FC pulleys?
Old Sep 9, 2010 | 05:51 PM
Howru's Avatar
I
You'll have to cut the spacer off the back of the FD pulley, as much of it as you can.
Old Sep 9, 2010 | 06:57 PM
alemmons's Avatar
89 GXL Turbo
Bummer, I don't have the FD pulley. Got the alternator without it. Any other ideas?
Old Sep 9, 2010 | 09:07 PM
go to an alternator Rebuilder.They will have the spacer.
Try your Local yellowpages.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Nosferatu
Sep 5, 2015 02:13 PM
