Need help pls!
Old Sep 2, 2010 | 11:12 AM
dgtz's Avatar
CA Need help pls!
Hey can anyone help me. I have a 91 rx-7 and when i drive it and turn on the fan the car stalls. Why is that? and how much do you think it will cost to fix that problem. thank you!
Old Sep 2, 2010 | 11:20 AM
613nn's Avatar
613nn
Do you mean the fan for the climate controll? Or did you install electric fans on the radiator?
Old Sep 2, 2010 | 11:46 AM
20Bforme's Avatar
three spinning triangles
more info needed.
Old Sep 2, 2010 | 11:58 AM
satch's Avatar
If you're referring to the Logicon fan then chances are your BAC needs to be given the look over. You also want the idle to be 750 to 800 RPM with the fan in the off position to start with.
