suspension bushings
Old Aug 31, 2010 | 09:09 PM
black89fc's Avatar
suspension bushings
where is a good place to get some bushings for my FC at a good price
Old Aug 31, 2010 | 09:44 PM
FelixIsGod29X's Avatar
Manual Rack
use google much? or the search function on this forum? under one minute and i found this, which is a fairish price.
http://www.energysuspensionparts.com...?prod=11.18101
Old Aug 31, 2010 | 10:56 PM
Spirit-RE's Avatar
Racing Beat.
Mazdatrix.
Etc...
Old Sep 1, 2010 | 10:51 AM
LunchboxCritter's Avatar
Disco Biscuit
Which bushings? The Energy Suspension complete bushing kit, is far from complete. If you have an S5 I would recommend buying them seperately. The complete kit contains end-link bushings that you can not use on an S5.
DTSS Elimination bushings are made by several companies. (not Energy)
There are 2 spherical bearing in the rear hubs that are expensive. They can be swapped with delrin ones if you eliminate the DTSS.
If you are planning on changing the bushings yourself I would recommend a shop press (12 ton or bigger). I would also suggest that as you need to drop the rear subframe to change the rear control arm toe bushings, that you also take the time to prep and paint/coat your subframe and related parts.
Old Sep 2, 2010 | 01:22 AM
black89fc's Avatar
i was gunna start with a DTSS Elimination i was just lookin for a good place that people on here buy from,
Postman09
Sep 29, 2015 11:23 AM
