LSD question
Old Aug 30, 2010 | 01:52 AM
bunnychopper's Avatar
LSD question
So I got a lsd from a 88 glx automatic 3.9 ratio and I want to go to the 4.1 lsd. Can I pull the ring and pinion gears out of an open 4.1 and put it into my lsd 3.9?
Old Aug 30, 2010 | 08:28 AM
Demonsniper1's Avatar
The cross-eyed kid
Yes you can just swap the ring/pinion gears from your auto onto the lsd since they are both NA. IF your car is open diff 4.1 then just swap the ring gear over before you put the lsd in and be done with it.
Old Aug 30, 2010 | 10:23 AM
Ok it sounds like it will work, but let me be clear. Right now I have an 3.9 lsd NA and I want to go to a 4.1 lsd. I figured it would be cheaper and easier to find a open 4.1 NA take the gears out and convert my 3.9 to a 4.1.
Old Aug 30, 2010 | 12:37 PM
RotaryEvolution's Avatar
Sharp Claws
you'll have to pay a shop to properly set up the pinion gear if you don't find a case with the already 4.1 gears installed into it. it's not an easy undertaking for the DIYer with no experience.
Old Aug 30, 2010 | 11:53 PM
I've installed rear end gears before. While I do know it is a bitch to set the torque on the pinion nut. I think I'll be able to handle it. The reason why I'm doing this is because I've installed a T56 camaro 6 speed with a .5 to 1 6th gear ratio. And 6th gear is useless under 80mph. I'd like to think I have a little experience.
Which way do you think would be easier keeping the case I have and putting the 4.1 gears in it. Or putting the clutch pack in the 4.1 NA case. Is that second option even possible.
One worry I do have is staying with a NA diff, maybe I should make the switch to the turbo diff but that would be 5 times more expensive.
Old Aug 31, 2010 | 09:53 AM
eage8's Avatar
1308ccs of awesome
I would put the 3.9 LSD into the 4.1 case so you don't have to touch the pinion gear, just swap gears and set back lash.
Old Aug 31, 2010 | 10:56 AM
RockLobster's Avatar
Let's get silly...
I have a 4.1 open rear end sitting around (no sub shafts) if you need one to throw the LSD into...
Old Sep 1, 2010 | 02:38 AM
Thanks but I think I'll look for one locally first. I just found a guy selling a diff out of manual glx for $50. I asked him when he turns one axle does the other turn in the same or opposite direction. This might be a steal.
Old Sep 2, 2010 | 12:14 PM
Sharp Claws
the LSD diff carriers are completely different so you only have 1 option, swap the pinions out.
Old Sep 2, 2010 | 12:27 PM
lastphaseofthis's Avatar
My job is to blow **** up
You wouldnt swap the pinions, just the LSD it's self. the ring and pinions have to stay together.
he needs to get a 4.1 OPEN diff. carrier and all, and just take the LSD part and remove the ring gear from it, and put the NEW ring gear from the 4.1 and put the 4.1 back togather and use that, then junk the old 3.909 pinion, ring gear and carrier(housing).
right? thats how i understand it....
Old Sep 2, 2010 | 12:32 PM
Sharp Claws
that's probably more accurate, if he can find one locally or have the case shipped. most people won't touch the pinion because they don't know anything about how to disassemble a diff properly.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
