Here is what Mikey has been up to :) Project Money Pit Update 2,000,000 :)
Old Jun 27, 2002 | 12:48 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Ok spent tuesday and wednesday on the car... I got the trans mounted, it is a simple redrill holes in the trans mount (not the x member) and it fits, Ill get pics of that later if someone is interested
The Haltech install is about 65% done. Only thing left is the Air Temp sensor, I have to make a new throttle body inlet anyways, so Im waiting on that. The coolant sensor needs to be done I have to go find an adapter today so I dont have to tap something thats already installed (front water pump housing) And the TPS is still yet to do, thats GONNA BE A REAL BITCH. Fellow Cosmo buddies give me a clue on this one
The o2 sensor is yet to do, but that will be on the downpipe that Im having made so its simple...
The Haltech is remarkably easy, the big scarey manual is the only scarey part. I have done alarm/remote starter combos that were way more intense than this.
PS Jeremy see I do actually do something when your not here (everyone jeremy comes by and Im standing around not doing anything )
Old Jun 27, 2002 | 12:53 PM
MIKE-P-28's Avatar
Another misc picture
Shows the 3 bar MAP sensor
Old Jun 27, 2002 | 12:56 PM
MIKE-P-28's Avatar
One more
Old Jun 27, 2002 | 01:28 PM
Directfreak's Avatar
I am a Jeeper Now.
I thought you were going to install it in the Glove-Box?
What's this?
Old Jun 27, 2002 | 01:29 PM
I am a Jeeper Now.
What's this?
Old Jun 27, 2002 | 01:58 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
If I had a multi-thousand dollar piece of electronics in my car, I don't know if I could just stick it under the carpet... I'd probably make a gold case for it and display it on the dash lol.
This car is going to be SICK.... there's just no other word for it. Off the ****** hook. Having a nice FD is cool, but having a first gen that can embarass most every one of them is unreal. The ultimate sleeper, surprising the hell out of anybody you run into.
It's great that we have people like Mike who are willing to pioneer this kinda stuff on the forum. I know it's not the first time anyone's done this, but to have it all chronicled out on the forum with pictures is phenomenal. I bet we're gonna see more of these in the future as people become aware that these seemingly dream-like possibilities are very real. And when people like me grow up and start making money to finance that kinda thing
Old Jun 27, 2002 | 03:45 PM
MIKE-P-28's Avatar
The PC hookup will flush mounted in the glove box, theres just way too much wire to get it in the glovebox, the wiring harness is a MAJOR pain in the *** to get through the firewall much less in the glovebox...By the way i wired up oil level, coolant guage, oil temp sensor, oil pressure, and the wiring for the alt... Not shown in the picture... By the way on the Haltech with terminated loom, you have to make your own connectors (with the supplie pieces and pins) for the CAS and coil packs It changes color on one side of the plug to the other (the car ones that is) and kinda had to think and double check it 3 times to make sure I was right
Old Jun 27, 2002 | 03:47 PM
MIKE-P-28's Avatar
The Haltech will be guarded by the factory piece of metal that supports the passenger well, actually its a good 3 inches to the floor, its probally better protected there than it would be out in the open
Thanks for the kind words, I often rely on the support of you guys too, I have thought MANY times that I should have just done a small block 400 with a nice carb and intake, headers and been done. But that wouldnt be any different than what Im going after, it would be kinda cool to say your 5.0, 5.7 etc just got stomped by 80 cubic inches!
Old Jun 27, 2002 | 05:35 PM
S2-13BT's Avatar
Mike,
I want a full, and very detailed account of the tranny install.
Please, please and please!
Thanks mate,
Christian.
PS. That's lookin damn good, keep it up and before long you'll be having a lot of fun.
Old Jun 27, 2002 | 05:55 PM
MIKE-P-28's Avatar
Originally posted by S2-13BT
Mike,
Thanks mate,
Christian.
Check the archives matey, setzep did a real nice writeup on it, the only other thing is the stock tranny mount (not the x member) has to be redrilled 5/8" froward, and 1/2" each side inward, its self explanatory, then use 1/2" spacers on the x member bolts to the body (lowers the trans and shifter down a little)
Old Jun 27, 2002 | 06:05 PM
MIKE-P-28's Avatar
MORE PICTURES
Old Jun 27, 2002 | 06:10 PM
MIKE-P-28's Avatar
NPR large IC in a FB
Yes the radiator does fit, done been there
Old Jun 27, 2002 | 06:12 PM
MIKE-P-28's Avatar
Homemade plugs to mate with the Haltech terminated harness
Old Jun 27, 2002 | 06:15 PM
MIKE-P-28's Avatar
Homemade plugs for Haltech wiring for s4 coil packs
Old Jun 27, 2002 | 07:05 PM
setzep's Avatar
Good job Mike! It's good to see that some people are making progress with there swap!
Old Jun 27, 2002 | 08:31 PM
MIKE-P-28's Avatar
****, w/o you id be going damn I just mess up rod #8 on a T2 trans, you made a shitload of progress.
Old Jun 27, 2002 | 11:06 PM
I am a Jeeper Now.
Theres a ghost in this image! Call the X-Files.
Old Jun 27, 2002 | 11:11 PM
I am a Jeeper Now.
Are these like GM connectors or something?
They look good and insulated for the heat.
I was planning to use the wiring harness out of my
organ donor car. That way the plugs,etc all look
similar.
Looking good so far Mike.
Are you going to mount the radiator directly behind the IC? You might have some overheating (well maybe not in KY). The Air immidieately aft of the IC is considerably hot. a 2 Core (instead of 3) might not keep up.
This is why I told you to mount the IC at an angle FC radiator style. Keep us informed.
Old Jun 28, 2002 | 12:29 AM
MIKE-P-28's Avatar
That would be smoke from my cig If id stop smoking, Id probally kill someone
Old Jun 28, 2002 | 12:34 AM
MIKE-P-28's Avatar
similar.
The radiator will be mounted in the stock location. You think you can mount a NPR IC like a FC, all power to ya I personally know its not as easy as it sounds...Without cutting down, or moding the endtanks.
I doubt I will have cooling problems anywhere in the US! Im probally gonna run multiple electric fans. also designing a sheet metal air damn under/behind the bumper so it forces air into it. Im running my turbos intake up there, so I can start with air thats about 30-40 degress cooler..
The Haltech comes with plugs for this, you have to crimp the pins and put them in the appropriate location.. I personally crimped and soldered the pins...
You see when you get yours... When you getting your hands dirty? LOL You gonna love mounting that TPS, think im gonna use the factory one
Old Jun 28, 2002 | 04:50 AM
AJC13B's Avatar
10.32 @ 133
I will get a shot of my TPS for you if I can....
Looking sweet mate, I seriously have to get my car stateside for a bit of fun with the yokels
Old Jun 28, 2002 | 09:06 AM
MIKE-P-28's Avatar
PLEASE do steve I bet they made something very intercate Beyond me, my fabrication skills are like zero
Old Jun 28, 2002 | 09:59 AM
jeremy's Avatar
male stripper
i think you just quit when i come over so i won't touch anything, lol. if there are any heat problems you could always try the water wetter. that stuff seems to work very well for the 3rd gen guys. you also need to update you sig that jeremy stole the 80's wires, air filter, and gas tank.
Old Jun 28, 2002 | 12:41 PM
j9fd3s's Avatar
Community Builder
the cosmo tps wires up the same as an fd one. thats a clean install of the haltech, it makes me want to redo mine. on mine i ran the serial cable into the glove box.
mike
Old Jun 28, 2002 | 07:06 PM
MIKE-P-28's Avatar
mike
Im not done yet Ive been doing electrical wiring on cars for 12 years, Ive learned a few things... LOL
@jermey stopped working my ***! that day you came by and matt was here with me, we just began working on the car and you left LOL Me and matt both said I guess jeremy doesnt wanna help LOL
