91 Tokico Blue Shocks, Eibach Springs Ideal Alignment?
I just installed dtss eliminators, poly bushings, and already had eibach springs, tokico shocks. I do not have an adjustable rear camber bar.
I would like to know what everyone recommends for camber/caster/toe settings for my setup. Car is street driven, and some aggressive cornering. I had it aligned before swapping the bushings, and I still had excessive understeer.
I'm guessing 0 toe, -1* to -1.5* camber, and as much caster as I can get?
Any and all help would be greatly appreciated.
You are correct I do not have aftermarket plates. The factory front mounts have 4 different settings depending on how they are turned. I also have some of the eibach camber adj. bolts (+/- 1* camber).
i set mine up with max negative camber/max positive caster in the front, which ended up being like -.6 camber, its stock. it still understeers with -.6.
i started with zero toe all the way around, and its awesome.
i did end up adding a little toe back into the rear, zero toe felt unstable if you were not on the gas in a turn. mine ended up being symmetrical side to side, so i just moved the adjuster a notch...
add a little toe in the rear = much more stable feeling.
rear camber is like -1.3ish, its stock too
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
