Fd With 19x10 with+50 offset
Old Jul 31, 2010 | 03:58 PM
SHOCKANAWE's Avatar
NJ Fd With 19x10 with+50 offset
Is there anyone who make a wheel like that?
Old Aug 2, 2010 | 11:31 AM
ARD T2's Avatar
Very doubtful unless it's a custom wheel.
What's the purpose of running this size? what size tire do you want?
Rishie
Old Aug 2, 2010 | 12:04 PM
Battle Cat's Avatar
Space cadet
sounds horrible...
also i think that would rub on the rear control arms... with such a high offset
Old Aug 2, 2010 | 12:55 PM
ptrhahn's Avatar
18x10" +50 is the the preferred track size, but requires aftermarket trailing arms and coilovers. You can run the rear w/ a 5mm spacer.
However, if you're not tracking (and you aren't likely to, because 275/30/19 track tires, the size you'd need, aren't made), there's no real reason to go 10" all around and need the +50 offset.
Better to go w/ a 19x10 +42 and up rear, and a narrower front, so you can get some clearance. There might be some rims at this size, but you could be looking at modulars like Work, Fikse, or CCW.
doritoloco
Sep 17, 2015 03:51 PM
