what kind spark plugs should i use for my single turbo set up?
Old Jul 26, 2010 | 02:51 AM
banski's Avatar
IL what kind spark plugs should i use for my single turbo set up?
hey guys.. i have a question.
i have 1993 FD with gt35r single turbo kit. some people say
use BUR9EQP spark plugs on T and L... is it true?
do you have any recommandation?
thank you guys..
Old Jul 26, 2010 | 11:42 AM
rxtasy3's Avatar
call up autozone, advance auto, pep boys, etc tell them u have a 93 rx7 and that u need ngk plugs for it. it's that easy. not sure bout the fd but the fc have specific leading and trailing plugs.
Old Jul 26, 2010 | 01:41 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes, run 4 x BUR9EQP if you intend on running more then about 15 PSI often.
Old Aug 2, 2010 | 05:15 AM
are-ex's Avatar
Brewster
L means leading spark plug which is the hole closet to the bottom of the engine trailing is above the leading spark plug meaning closet to the top of the engine
Joe428
16
Aug 19, 2015 06:24 PM
