a 3 rotor Renisis?
Old Jun 26, 2002 | 06:23 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
a 3 rotor Renisis?
From what i gather, you can make a 3 rotor out of any series engine, the 12a 13b's, now what about the renisis? its 240+ ponies n/a, Not bad at all for a wankle, but could you construct a 3 rotor out of it?
it would have to produce some crazy HP
i woke up and this is the first thing that came to my mind
Old Jun 26, 2002 | 12:08 PM
nobody? 15 views and nobody has any input of any kind?
Old Jun 26, 2002 | 01:06 PM
mmaragos's Avatar
With "crackhead" in your name...
Sure. It can be done. Many...MANY custom parts. And what is the availability on the Renisis right now?
Too expensive, too time consuming and too many issues.
Better off going with a 20B.
Old Jun 26, 2002 | 04:04 PM
RX-Heven's Avatar
I'll blow it up real good
I don't think you can make 3 rotor from a Renesis due the the new location of the exhaust ports in the side housing. This is what gives the Renesis better torque due to a decreased overlap between intake and exhaust. This topic came up once before awhile back and I think RETed was able to explain excatlly why this wasn't possible as a result of the new exhaust port location.
Old Jun 26, 2002 | 08:33 PM
Oh, i haddent hurd anything about the exhaust port,
i knew that even if it could be done it would cost alot because of all the custom parts needed to be made, i was just wondering if it was possible becase the awsoem power that it made with 2 rotors,
oh well, was a nice thought
Old Jun 27, 2002 | 12:25 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
I read that thread too way back when and yes somethign about the porting being in the side and the physics were just too difficult. but I bet mazda does come up with something since they are planning racing them.
Old Jul 2, 2002 | 03:56 PM
protlewski's Avatar
hey why would it not be possible. the thing still has intermeidate side housings. those have the side exhaust ports on both sides. the e-shaft shouldn't be all that differien't and all I see you would need ( 'cept for the custom e-shaft and other numerous parts) is two renesis's to take the inter' housing off of.
Don't flame me too bad but thats what I think.
Old Jul 2, 2002 | 04:18 PM
j9fd3s's Avatar
Community Builder
well, if they didnt change the bearings you could use the 20b eccentric shaft, with the renisis rotors. the center stationary gear would have to be 20b. you would use 3 renisis rotor housings, the rear renisis steel, the center steel. but what are you going to do for the front housing an the front middle housing?? those are both unique to the 20b, and you cant put the renisis ports in the 20b side housings. besides you cant get a renisis yet.
mike
Old Jul 3, 2002 | 02:19 AM
KraftDinner's Avatar
If power is your main concern, you would be better off building a current 20B engine instead of a renesis-20B.
I say this because the renesis, even though it makes much mroe power than a 13B, is engineered with emissions and fuel economy and reliabliity as the main concerns. The power increase is mainly due to the increased compression ratio - not the change of exhaust porting. If you had a current 13B with a street port and the same compression ratio as a renesis, I bet it would make more power.
Am I wrong?
Old Jul 3, 2002 | 10:53 AM
j9fd3s's Avatar
Community Builder
maybe, maybe not; we dont have the renisis yet to even check
mike
jase03
26
Sep 29, 2015 10:36 AM
20B Forum
Sep 22, 2015 07:39 PM
ZacMan
Sep 19, 2015 09:20 PM
Ian_D
Sep 6, 2015 10:38 PM
