NA parts interchanging with TII
Old Jun 26, 2002 | 12:51 AM
edomund's Avatar
Bastardized RE AE
I am wondering if any one knows if NA parts interchange with TII parts. I might buy a TII that caught fire under the hood so I will need parts. I know not all will interchange like wire harness etc. But hopefully some will.
Here's a list someone gave me of what needs to be replaced when a car catches fire.
Engine Wiring Harness
Fuel Injectors
Fuel Rails
Fuel Hoses
Pulsation Damper
Oil injectors
Oil injector lines
Vacuum "Spider" Setup
Various hoses
Wiper Motor
Wiper Motor Wiring Harness
Windshield Washer Hoses
Intake Gasket
Throttle Cable
Cruise Control Cable
-Ed-
Old Jun 26, 2002 | 12:56 AM
SonicRaT's Avatar
Super Raterhater
Engine wiring harness: you need the Turbo harness
Injectors: no, na have a lower flow rate
Fuel Rail: No, on the NA the pulsation damper is on the other side (with s5), and the intake hits it and can't bolt down
Pulsation damper: see above
Oil injectors: yes
Oil injector lines:yes
Vacuum spider: The metal spider? or the octopus for the oil injectors?
Various hoses: too open to know
Wiper Motor:yes
Wiper motor harness: it's the engine harness
Washer hoses: yes
Intake gasket: nope, have to have the turbo gasket
Throttle cable: no, NA is short, t2 is long
Cruise control cable: nope, too long
I hope this helps.
astrum
24
Nov 15, 2017 08:44 AM
Professorpeanutrx7
Aug 18, 2015 03:09 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
