Introduce yourself New members post about yourself here...
turbo II rebuild
Old Jul 18, 2010 | 02:02 PM
dariush_fc4's Avatar
turbo II rebuild
i am on my third rx7 but this one is a series 4 turbo II ! i have the engine fully out and am in the process of rebuilding it the car came from texas with no rust anywhere 85k on body jspec motor got the car for 600 bux interior is very clean good there is however a dented driver fender and door so i need to find those in the sunrise red i have never rebuilt a rotory so wish me luck guys!
Old Jul 21, 2010 | 01:19 PM
FBS5T2's Avatar
Good luck! You should have fun if you're not in a rush. What year and model were the other two you have or had?
Old Jul 22, 2010 | 01:35 PM
my first was a non running 1986 blue/gray got it running didnt make it lone stripd it down for parts my second is in my grage too right now still runs just needs a clutch and brakes hooked back up it is a 1988 GTU i took the 5 lug and switched it to me t@ becuz the guy that wrecked the engine took the original 5 lug but i had drilled/slotted rotors and new calipers the hole shebang. i just got my blocked pulled apart and it is probably the worse rotor i have ever seen its chipped to **** the seals that are no longer in there proper notches are now welded to the side of the rotor it is a mess i will post a image and i think we should all post images to see whos got the most fucked up rotor haha but now i get to find t2 rotors
Old Jul 23, 2010 | 10:40 PM
OneSickRx3's Avatar
Rebuild?
How much is your rebuild going to cost you? I'm trying to rebuild my motor, but don't know how, any suggestions?
Old Jul 28, 2010 | 04:19 AM
ReijinZro's Avatar
good luck hope you get it on the road soon.
Th0m4s
Feb 26, 2019 02:04 AM
incubuseva
14
Sep 3, 2015 12:37 PM
