need help determining fitment of wheels and tires
Old Jul 16, 2010 | 12:34 AM
canyontougeFC3S's Avatar
Arrow need help determining fitment of wheels and tires
Picking up a set of 16 inch BBS wheels off of a 99' Ford Crown Victoria and plan to mount a new set of Bridgestone Potenza S03 Pole Position's on them. The spec on the wheels are 16x7 and 16x8 with unknown offset from my knowledge they are 0 offset, about 4" backspacing. The tires are 225/50/16 52w front and 245/50/16 54y rear. The car is a 1991 Mazda RX7 FC3S. please help me determine wether they will fit or not, i'd greatly appreciate it
-ernie a.
Uploaded with ImageShack.us
Old Jul 16, 2010 | 12:47 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Here's a thread I turned up in the 2nd gen section about zero offset wheels: https://www.rx7club.com/2nd-generation-specific-1986-1992-17/16x8-0-offset-911428/. There are others, but this seemed to cover it. They're going to stick way out, and probably require coilovers + excessive camber or fender rolling. Zero offset is FOUR cm further out than stock.
Old Jul 16, 2010 | 02:53 PM
CA
Originally Posted by RotaryRocket88
Here's a thread I turned up in the 2nd gen section about zero offset wheels: https://www.rx7club.com/showthread.php?t=911428. There are others, but this seemed to cover it. They're going to stick way out, and probably require coilovers + excessive camber or fender rolling. Zero offset is FOUR cm further out than stock.
okayy i kept searching and apparently the wheels arnt 0 offset, they're roughly +30-35 offset. here i even found a picture of fc's running this wheel.
http://img.photobucket.com/albums/v2...916081238c.jpg
