Power FC Looking for FC Edit versions
Old Jul 7, 2010 | 08:24 AM
FastHatch's Avatar
Hello everybody,
if you have a FC Edit version not listed here (excluded the universal ones), please post it here or email it to me (andre at fctune com).
Reason why I need them is because the log file format has often changed between the different versions. There are subtle bugs and differences, which most of you probably haven't noticed.
To ensure that all the different formats are handled correctly, I need all released versions of FC Edit.
I also have automated tests running, where the log files are opened and saved and then the saved file compared with the original one.
Thanks Andre
Old Jul 8, 2010 | 09:36 AM
FastHatch's Avatar
Here is an example for the RB25DET. 3 different FC Edit versions, 3 different formats.
When you open a log file in FC Edit it reads the file "as-is", that means the values are not interpreted. FC Tune scans the file to figure out the format and then interprets all values correctly. It also silently fixes the known bugs. That's why it needs to know all formats and why I need all different versions.
Please also post non-RX7 log files if you have and post a link on other boards.
Old Jul 8, 2010 | 09:52 AM
FastHatch's Avatar
Also please note that the values here are wrong:
O2S can only be a multiple of 20mv. The problem here is that Edit calculates the values as a multiple of 5mv instead of 20mv, so all values are off by factor 4.
(FC Edit Universal for the FD3S has the same bug btw.)
Old Jul 22, 2010 | 06:44 PM
paulr33's Avatar
as per
http://www.skylinesaustralia.com/for...8#entry5361698
lookup the email address for user STATUS and drop him a note
he runs a workshop and has SR20 and RB26 logs
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
