4 to 5 lug swap
Old Jun 28, 2010 | 10:41 PM
newtorotaries_guy's Avatar
NV 4 to 5 lug swap
Ok I want to do a 4-5 lug swap on my FC. I know on nissans i just had to get the whole hub for the front and rears and do a one for one swap. Is it the same for a FC? Please advise. Thanks.
Chris
Old Jun 29, 2010 | 11:11 AM
RotaryRocket88's Avatar
Top Down, Boost Up
https://www.rx7club.com/showthread.p...light=lug+swap
Old Jun 29, 2010 | 04:22 PM
thanks, but it sounds like the rears i might have to do a subframe swap? That really does not tell me how to exactly do it..
Old Jun 29, 2010 | 06:38 PM
misterstyx69's Avatar
Retired Moderator, RIP
You need to get the rear spindle/hub assembly with the brakes.
The assembly comes off with 3 bolts.the Worst one being the TOE Bolt which is a 21 MM Bolt from HELL.
If you take it off without ripping the Rubber Bushing out of it,Consider yourself VERY Lucky.Most People just say "screw it" and when they Rip the bushing all to Rat-**** ,they get a set of DTSS eliminator Bushings at www.Mazdatrix.com .
Keep that Web address.You will use it Often If you need stuff for your FC.
Old Jun 29, 2010 | 06:51 PM
i appreciate it. I already sourced a set here in las vegas. Thanks for the website!! I will keep that in mind..
Old Jun 29, 2010 | 08:02 PM
If you get stuck just PM me..
OR you can private message me your Phone number.(seriously).I have Free long distance.(.YEEHAH..yak,yak,yak!).
I have done 5 of these 4-5 lug swaps,so it isn't new to me.
Old Jun 29, 2010 | 09:00 PM
great thanks man!! i really appreciate it!!
