Megasquirt any problems using tunerstudios
Old Jun 28, 2010 | 09:55 PM
13bdarren's Avatar
I can't seem to get tach signal right it seems to be doubled. I get a edis error too when i set it up. I am pretty sure I have everything set right. I have spark mode set to tooth wheel but I cannot set trigger offset /angle deg. It is just shaded out. I tried other setting but then it shades out trigger wheel menu. I might try playing with the cas wiring to see if it fixes thing but the menu stuff is what is puzzling me. Thanks
v3 ms2 with newest code
Old Jun 29, 2010 | 05:06 PM
muythaibxr's Avatar
MegaSquirt Mod
This shouldn't have anything to do with tunerstudio. Post your msq and we'll take a look.
Ken
Old Jun 29, 2010 | 07:30 PM
13bdarren's Avatar
here is my msq I am just starting from scrath don't have all the tables filled in yet. I reloaded the code and seems to be better but get really bad tach signal. I also cant adjust trigger angle
File Type: zip
Old Jun 30, 2010 | 05:36 AM
13bdarren's Avatar
I think I found the problem. I download the the beta code instead of the stable one I will try the 2.xx code tonight. I was using 3.03u
Old Jun 30, 2010 | 08:48 PM
13bdarren's Avatar
Great sucess the right code made all the difference. Sometime spelling out the problem helps you figure it out yourself.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
