Negative Camber Adjustment (searched)
Old Jun 16, 2010 | 12:04 AM
20B 3 Rotor's Avatar
This may not be the right section, but I figured I would get alot more views posed in the 3rd section.
Anyways, I just installed some wide rear tires on my Fd, and I had to adjust the rears to maximum negative camber. Only problem is I just need a smidge more (maybe just 1 degree or a little more) negative camber for the rears to not rub.
Im just wondering what options I have to get just slightly more negative camber in the rear?
Thanks.
Old Jun 16, 2010 | 01:05 PM
Josh18_2k's Avatar
whats the point of big tires if you have to run too much camber to clear them? its not helping grip any..
Old Jun 16, 2010 | 03:27 PM
windchaserfc3s's Avatar
That's definitely true. Did you roll your rears?
Old Jun 16, 2010 | 10:21 PM
No, I have origin overfender flares on the rear, I have done as much as I can with the fenders, so it comes down to camber, I dont want to have to stretch the tire anymore (trying to have as little stretch as possible).
Btw, as the camber sits right now, theres more then plently of contact with the tires.
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
FD3S_wanted
Sep 22, 2015 06:18 PM
04G35S
Sep 9, 2015 07:05 AM
