anybody have a pictorial DIY of how to replace the rear studs on FD?
Old Jun 11, 2010 | 07:21 PM
muibubbles's Avatar
Bubblicious DEF.
looking to replace my studs for longer ones... anyone have a diy? i have the manual but always found it easier with pics... also do you really need to replace the bearing?
Old Jun 12, 2010 | 01:23 AM
mannykiller's Avatar
Garage Hero
thats so funny... got my ARP extended studs 2 days ago and havn't tackled it yet because of this same question haha.. let me know if you find anything.. i'll do the same brotha!
Old Jun 12, 2010 | 03:56 AM
widebodyseven's Avatar
Formerly widebodyseven
Im replacing mines right now but for a FC.
For oem studs you might be able to do it with out removing hub but not sure for the FD.
For extended studs you have to remove the hubs.
Bang the old ones out and put the new ones in by using your lug nuts to pull them through the holes or just hit the back of the studs.
For the bearings im not sure if you "need" to replace them unless there damage like mine bc i was hammering it to separate hubs from the axles
Old Jun 15, 2010 | 02:14 AM
muibubbles's Avatar
Bubblicious DEF.
^^incorrect, you NEED to pull the hubs out for the rears..... the manual says replace the bearing but my shop swapped one of the studs and i never gave them a bearing so im assuming the same one was used........? just wanted confirmation
Frisky Arab
13
Aug 18, 2015 05:30 PM
