2 questions simple really
Old Jun 8, 2010 | 01:47 PM
canonize-ryda's Avatar
ok first my rear end wheels look a lil lobsided u can see in my profile pics. is that normal or should i replace cvs or something. and where can i find a link to see the vaccumm diagram for the na s4 13b?? thanks
Old Jun 8, 2010 | 01:58 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Negative camber on the rear wheels is normal. Vacuum diagrams are in the FSM fuel and emission section. You can also find colored-in versions by searching the 2nd gen section.
Old Jun 8, 2010 | 02:18 PM
funkjaw's Avatar
Negative camber is normal especially when you lower the car. If you are unsure get down there and check all the components to make sure you don't have a bent lateral link or something.
Old Jun 9, 2010 | 08:38 AM
Aaron Cake's Avatar
Engine, Not Motor
You'll probably find all your bushings are worn and your springs are sagging. Such is the case of 20+ year old cars.
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
Nosferatu
Sep 5, 2015 02:13 PM
