How to remove twin scroll from manifold?
Old Jun 23, 2002 | 10:52 PM
Drakk0r's Avatar
To those who have removed it? How'd you do it? I can cut it out, but I dont like having to cut things out. Is there somthing I'm missing?
Old Jun 23, 2002 | 11:34 PM
moremazda's Avatar
Gone Race'n
I cut off the out side arm and drilled out the shaft. (stuck a drill bit in the hole and didn't stop the drill untill the falpper fell out) I then tapped the hole and ran in a grade 8 bolt and tourqed it down to 120 ft/lbs. Nice and clean.
Ryan
Old Jun 23, 2002 | 11:42 PM
RETed's Avatar
I hope you realize you need to remove the turbo (at least) to do this properly.&nbsp Just bang the lever with a hammer, and this will torque the thing right off.&nbsp The lever is just brazed onto the shaft, so it's not that strong.
The rest of the write-up is here...
http://fc3s-pro.com/TECH/HOWTO/EGT/egt.html
-Ted
Old Jun 24, 2002 | 12:17 AM
Drakk0r's Avatar
Ok, thanks.. I was hoping it was put together differently... I already have the manifold out.. I was just trying to avoild mutilating it too badly Oh well...
