87 t2 collant light help .
Old Jun 23, 2002 | 08:48 AM
new recruit's Avatar
Just put in a DIY FCD and it tested fine but now the coolant light and buzzer comes on seconds after tuuning key to on. I triple checked all the connections on the FCD and ruled that out . What else can make light come and what should I check ? and is the boost sensor curcuit have anything to do with it. And yes it is full of coolant and the temp is fine.
thanks
Old Jun 23, 2002 | 09:39 AM
StarionX's Avatar
If you remove the FCD, do the lights still come on? If not, then the problem is with the FCD.
Old Jun 23, 2002 | 09:20 PM
The light still comes on when I unplug the boost sensor. Maybe its just a coincidence but its sure funny. I drove it pretty hard the last time I Had it out, then I screwed with FCD then I started it. The overflow was low but the at the rad cap was full. I topped up the overflow but the light still came on. Hmmm.
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
