FC3S Oil Hose Pop..
Old May 24, 2010 | 03:55 PM
Topless_FC3S's Avatar
FL FC3S Oil Hose Pop..
Ok the Line or hose that connects to the Oil Cooler and runs to the motor... Thats a High Pressure Oil Line Correct? and How difficult is it to replace? Also, the pricing on it.. I went to autozone and advance auto and they dont sell it...The Mazda Dealership relocated almost an hr away I believe and The RX is my daily/only car... So Any Suggestions... if its the Oil Pressure line.. once again it runs from the Oil Cooler in the bumper to the Motor...its like a Soft thread hose... its leaking out badly... Cant even drive the car.. Motor still cuts on and runs no problem but not driveable due to a quart is gone in Minutes..
Old May 24, 2010 | 07:41 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Oil cooler lines. You should replace both of them. Here is one source: http://www.corksport.com/corksport-s...s-for-rx7.html
sYnth.
Aug 19, 2015 06:27 PM
