Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Todays stupid question, Check boxes.
Old May 6, 2010 | 10:41 PM
AUGieDogie's Avatar
So, I just want to make absolutly sure of this. ...
If the boxes for Rev limiter, map based timing and omp are CHECKED then the limiter is raised, map based time is on and the OMP is DISABLED.
I have them all unchecked right now. Because i wat the stock limit, no timing changes and absolutly, positivly a working oil metering pump.
I don't want to blow my engine so i'm double checking.
Thanks
aug
Old May 7, 2010 | 10:30 AM
turbo2ltr's Avatar
This is correct.
Old May 7, 2010 | 03:40 PM
AUGieDogie's Avatar
thank you
smikels
Rtek Forum
May 12, 2016 12:34 AM
Microtech
30
Apr 23, 2016 06:37 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
