Compression Testing QUESTION - Yes i searched...
Old May 3, 2010 | 06:53 PM
DallasFC1's Avatar
Jack of All Trades
TX Compression Testing QUESTION - Yes i searched...
There seems to be something i am unsure of (my first carb'd engine...).
When performing the compression test, should I unplug anything in the way of IGNITION? Car has no plug wires on it at the moment, and wanted to compression test tonight. I just don't want to be mildly electrocuted by touching the chassis/body while cranking the car with no wires on it...
On my 86 and 88 all i had to do was unplug EGI fuse, but that is irrelevant here..
Any help?
Thanks,
Old May 3, 2010 | 06:58 PM
Whisper's Avatar
Pull blue connector off the trailing coil.
Old May 4, 2010 | 09:19 AM
Sgt Fox's Avatar
Stigulus Moderatorai
If you had read the mazda FSM you would know that you don't need to pull anything for a 12A aside from spark plugs. Also, mildly electrocuted would be the same as extremely electrocuted, as electrocuted means to die from electric shock.
Old May 4, 2010 | 09:34 AM
DivinDriver's Avatar
1st-Class Engine Janitor
Medium rare versus crispy critter?
Old May 4, 2010 | 10:32 AM
rotarydude's Avatar
Back in the saddle again
That would be the difference between Low Output coils vs High Output coils LOL,,,, JK
LunchboxSA22
37
Oct 26, 2015 10:53 AM
elfking
Aug 19, 2015 09:48 PM
