DIY shock boot write-up for Koni Yellow
Old Apr 24, 2010 | 11:31 AM
wanklin's Avatar
Rob
VA DIY shock boot write-up for Koni Yellow
Tools: spring compressors, heavy-duty scissors
Parts: Energy Suspension 9.8130G Black Shock Boot - 2 Pair (approx $7 per pair)
SLIDE SHOW:
http://picasaweb.google.com/10378824...31529479181394
wanklin's Avatar
Rob
Hope this helps someone
Old Apr 24, 2010 | 12:04 PM
wanklin's Avatar
Rob
UPDATED LINK:
http://picasaweb.google.com/10378824...31646341310146
Old Apr 25, 2010 | 06:57 AM
tabuk1!'s Avatar
Originally Posted by wanklin
A pretty useless post other than to say nice work. It's guys like you that make this forum so informative ... a great resource for old noobs like me who still like tinkering with these great machines!
Old Apr 26, 2010 | 02:27 PM
rotarymaz's Avatar
Do you know what's the width/diameter of the boots? I have Ground Control kit on my Koni, with 2.25" ID Eibach springs. I wonder if these will clear the springs.
Old Apr 26, 2010 | 04:31 PM
wanklin's Avatar
Rob
These are 3" at the widest end which is barely large enough to fit around the shock mount neck. I don't think these are going to work for you. You'll have to look for something more narrow and find a way to attach it. These boots are perfect for stock diameter springs however.
See specs here:
http://www.energysuspensionparts.com...FQk65Qodciqexg
Old Apr 26, 2010 | 05:06 PM
wanklin's Avatar
Rob
I appreciate the kind words.
Old May 20, 2010 | 05:56 PM
GtiKyle's Avatar
Uncle Rico
Community Builder
Top Answer: 1
I'm wondering if boots are even needed? Most aftermarket shocks/coilovers don't really utilize a boot...Trying to decide if i should slap on my Koni's, or if i need to do boot installs..
Old May 20, 2010 | 07:19 PM
wanklin's Avatar
Rob
A lot of people use Konis without boots; however, Koni supplies metal boots for its OEM applications.
Old Aug 21, 2012 | 08:43 PM
chiefboon's Avatar
Highwayman
Does anyone have the instructions/paperwork that came with the Koni yellows handy that they can scan? I would like to adjust perch setting but would like to read instructions. Much thanks!
antman0408
Oct 5, 2015 04:33 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
