idle and hesitation problems
Old Apr 21, 2010 | 07:53 PM
rotarycity's Avatar
hey guys I'm new to this site and the rotary scene just got an fc s5 that has some problems idling it is bouncing between 1500 and 2000 and when I start it sometimes idle drop so low it dies. the other problem that occurs is during acceleration it hesitates pretty bad but not always at same rpms just when ever I get on it a bit. could these problems be related and does any one have any ideas?
Old Apr 21, 2010 | 09:44 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Typically a vacuum leak or bad/misadjusted TPS.
http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1
Old Apr 21, 2010 | 11:12 PM
tangoshark's Avatar
sherevvs
My 88 N/A vert has the same idling problem! but not everytime though. Tonight when I first started it cold, idle drops so low and it died, after restarted I gave a little gas but still bounces between 1500 to 2000 rpm. After I ran it and the car warmed up the idle problem is gone.....
Am I having the same vaccume leak problem?
thanks a lot
Old Apr 23, 2010 | 09:44 PM
Topless_FC3S's Avatar
No doubt it... My 90 Vert does the samethinq... on a fresh start qive car a lil gas and the idle will bounce jus for a minute then soon as it warms up a little youre golden... Nothing really major...
Old Apr 23, 2010 | 10:56 PM
Erix7rew's Avatar
First tps ajustement, second new spark plug and cable, third new O2 sensor and forth if the 3 other one dosent work, check for a vacuum leak
Good luck
Eric
Old Apr 24, 2010 | 01:19 PM
bhop's Avatar
Semi P-PORT
Ignition coils, as well as spark plugs/wires
Old Apr 29, 2010 | 10:17 PM
~slidewayz fc3s~'s Avatar
mine does the same thing.. i was told its the bac valve???
oh and what is the "tps" sensor?
Old Apr 29, 2010 | 10:22 PM
whoa!!! sorry! ima a dumb ***! had to think for a sec... throttle positioning sensor DUH!!!! :p
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
rx7shirley
Sep 2, 2015 02:11 PM
