PFS PMC Area for discussing the Peter Farrell Supercars PMC/PMS.
PFS PMC Purple Box Hand Controller ( black box ) readout questions
Old Apr 21, 2010 | 07:49 PM
David0ff's Avatar
Just making sure of a couple of things
when the car is off .. and i switch the ignition to ON ... amongst others the pad comes online ...
now .. on menu I .. on the top corner it reads IDLE .. then when i press it says something else ( PR H i believe ) ... ... but i cant get it to say when i press the accelerator at max WOT , i have checked/adjusted the TPS withing spex ... and even when the engine is running .. it goes from idle to .. low .. 2-3-4-5... med .... 6-7-8.. but i don't recall ever reading WOT ..
is WOT actually part of it`s vocabulary ? .. or PR H = WOT ?
thx
i dont have any alterations in the WOT maps .. only in the max boost .. part l/m/h areas .
a/f on my wide band is good under boost ... EGT`s as well
will i have a problem if it cant read WOT ?
thx
Old May 3, 2010 | 12:44 AM
David0ff's Avatar
alright i got it to work ...
btw i luv this little toy
