Suspension/Brake Question
Old Apr 20, 2010 | 01:33 AM
WiredRebel's Avatar
I am looking to order a set of brake pads for my jdm 92 fd (R1 model) and I was looking to hawk for a set of their HP Plus pads.
However when I look for pads it asks me if I have standard suspension or electronic adjustment suspenion. If I go with standard suspension I can only find the pads for the rear but if I go with the electronic I can get both from and rear pads.
So here is my question. Is there that big of a change between the electronic suspension and the standard?
Dose it warrant me worring about getting stuff that may not work since I dont have the electonic?
Or is everything the same with the brakes and I should order the pads?
As stated before my car is a JDM 92 FD (R1 model)
Thanks for your time and responses.
Old Apr 20, 2010 | 08:49 AM
Mahjik's Avatar
Mr. Links
I would recommend Carbotech AX6 if you are looking for a street/autox pad:
http://carbotechperformance.com/pads.asp
Expensive, but a good pad. If you want something a little cheaper, Bonez Stage I:
http://www.rx7.com/store/rx7/fdbrakes.html
Old Apr 20, 2010 | 09:51 AM
WiredRebel's Avatar
Ok but that dosen't answer my question about the suspension. I just want to know if there was a difference between brakes setups on the electronic and the standard.
Old Apr 20, 2010 | 10:22 AM
Mahjik's Avatar
Mr. Links
There was no electronic suspension for the FD3S.
Old Apr 20, 2010 | 10:34 AM
WiredRebel's Avatar
Ok, thanks for the info/time.
Old Apr 20, 2010 | 11:16 AM
gracer7-rx7's Avatar
needs more track time
Usually that reference to electronic suspension is related to the FC - specifically the GXL 'electronic' suspension.
Try searching for pads for 93-95 RX7s to get the right parts.
Old Apr 20, 2010 | 10:59 PM
WiredRebel's Avatar
I was searching from hawk because I have a local guy that can get me a good price and he runs hawks on his dd/weekend autocross car and loves them.
When I was on their site thou and put in standard suspension (Because I never knew of an fd with electronic) it only came up with the rears.
I than went to another website (forgot which one) and say that they did have front pads for an fd but they were under the electronic suspension I thought it would be a good idea to ask before I buy and find out they don't work.
So thanks again for everyone who helped me out with this question.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
