Fc ingition parts into Fb
Old Apr 9, 2010 | 10:35 PM
009's Avatar
009
I want to do this ignition mod like every on here talk about. I got a pick n pull fc rx7 with ignition and 2 coils still intact. That all I need to pull out and swap it in my fb? Or i need more then just that. Thanks for little help with new fb owner. Oh just change m/t fluid to GM synchromesh and flush my coolant. Any one use GM synchro on here?
Old Apr 9, 2010 | 11:31 PM
Rehd's Avatar
Push The Button
If your talking about the coil modification then all you need is the leading coil. search for around in the archive and you will find it.
If you mean the full ignition swap there might be a write up around here somewhere but im not sure. SEARCH!
Old Apr 9, 2010 | 11:36 PM
009's Avatar
009
I did search and found it. It so confusing and nto very clear to me. I am such a newbie
Old Apr 9, 2010 | 11:47 PM
rxtasy3's Avatar
give a shout to bad_83, bwaits or t_g_farrel. they've done it.
Old Apr 10, 2010 | 12:59 PM
hoang5659's Avatar
009,
when you get more info on how to do this mod, can you please send it to me also? i have been wanting to do this mod also. thanks.
hoang
Old Apr 10, 2010 | 04:09 PM
009's Avatar
009
As far as i know, i need to get ignition from fc, 2 of them, plus 2 coils, and a msd with a modified gutted ignition. I am reading up on HOW TO by b20jeff. It a little confusing and still trying to figure ti out. Cuz MSD is quite expensive...
Old Apr 10, 2010 | 07:37 PM
rxtasy3's Avatar
only the leading fc coil.
Heedlessone
288
Sep 16, 2018 07:22 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
