Sponsored by: CARiD
Question about compression test
Old Apr 5, 2010 | 08:07 AM
Ipohboy's Avatar
Today I visited some workshop to kill time , and I saw the mechanic there did a compression test using rotary comp tester (comp 07S).
He pulled the fuel pump relay located at the front bumper fuse box. Then I watch he cranked the engine for 5 seconds (the tester got count down timer) without accel pedal to the floor.
I always thought that we must pull the the EGI relay and when doing the test we must open the throttle (accel pedal to the floor) ?
Is there any difference doing the test with and without opening the throttle?
Old Apr 5, 2010 | 06:22 PM
rxtasy3's Avatar
nope.
Old Apr 5, 2010 | 07:55 PM
Elcocue75's Avatar
El Coqui
Wow
I am new to all this but I just learned something new, thank you for the information.
Old Apr 8, 2010 | 10:26 PM
misterstyx69's Avatar
Retired Moderator, RIP
I hate to disagree but I do!.I was taught Wide open throttle so that the engine can Get air,no restriction and therefore give you a Good Comp Test.A closed TB( at idle) will not let the engine get Good air.
I would do another test with Open Throttle.It can variate the Test by at least 15PSI.
Old Apr 17, 2010 | 11:47 AM
Sideo's Avatar
if the throttle is not open, it will pull vacuum and thus a resistance to turn and will not crank as fast and not give as high of a compression.
LunchboxSA22
37
Oct 26, 2015 10:53 AM
elfking
Aug 19, 2015 09:48 PM
