Introduce yourself New members post about yourself here...
ROTARY is in my DNA
Old Mar 23, 2010 | 10:17 PM
KS2626's Avatar
ROTARY is in my DNA
hi Guys,
I just bought a used FD 1994 spec R2 and had many queries in my mind.
The car has LSD, manifold, wastegate and new turbo of GT35, roll cage, and lots of mod. Unfortunately, the 2 of the rotor from the engine does not work , even the microtech ECU was certified old.
Having in mind, i intend to have street port n rebuild back the engine and get a new microtech ECU.
1st Question - How much horsepower will it have?
2nd question - How much Horsepower can the gearbox withstand?
3rd question - There is a leakage from radiator cap filler area. does the problem arises due to factory fitting problem or i need to change the parts such as water pump housing.
4th question - where can i buy cheap parts/accessories such as the reading meter (need to change to white colour instead of black)
5th Question -How fragile is the engine? Due to i am hard core driver and if it is fragile i may need to build another set of engine and take it as spare in the case it boom.
5th question - is there such a need to change to aluminium radiator?
6th question - How much difference are there between R1 , R2 and 2002 model. i believe the shape is the same, how abt the engine.
7th question - Will stock clutch/housing able to withstand 450-500 hp?
I am just started off with rotary. Please assist if you can answer my question.
thanks a lot.
Kenny
Old Mar 24, 2010 | 10:22 AM
gracer7-rx7's Avatar
needs more track time
Many good questions there. All of them are answered in the FAQ thread. Spend some time reading it and come back and post in the New Member Technical Section if you have any further questions.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
