rotrex supercharger?
Old Mar 23, 2010 | 01:45 PM
dkaszak88's Avatar
NJ rotrex supercharger?
any one ever see the rotrex supercharger im curious if any one has built a rotary setup with this unit. i know they make a kit for a miata, right now i have a gtu i wanna do a big street port and then possibly supercharge. but i hear the camden and paxton/nelson dont exist anymore, and im exploring my options. any info?
Old Mar 23, 2010 | 10:08 PM
farberio's Avatar
NASA-MW ST4
Camden still exists, but they are costly and the gains are small in comparison to a similarly priced turbo build.
http://www.camdensuperchargers.com/
Old Mar 23, 2010 | 10:27 PM
dkaszak88's Avatar
i wanna do a big street port or a half bridgeport, then possibly do superchager. how much whp can i get from a street port or a bridgeprt? im looking for around 200, my goal is to do low 14s maybe high 13s but i mainly wanna do auto x
Old Mar 23, 2010 | 11:23 PM
84stock's Avatar
Camden will give very good torque, great for autocross. However, you will never see much over 200 rwhp. Invest in a properly sized quality BB turbo and a haltech.
Old Feb 27, 2011 | 11:16 PM
pops the eveo killer's Avatar
That is not true. Do your research for $2000, you can achieve anywhere from 100 to 500, on a 2 rotor or 400-800 on a 3rotor you can even set up duels.
Give krafworks a call 2050 5th Street
Norco, CA 92860
United States
Tel: 951.808.9888
all they need from you is the highest rpm the engine will see. The base pulley size and how much hp. you want. and the best part is the
unit pumps its own oil and very little heat.run it into a small water to air inter cooler mount it on the drivers side away from the exhaust you can use your n/a header instant throttle response and all the top end you can use if you did you would know that this unit is perfect for a rotory
Old Feb 27, 2011 | 11:20 PM
O AND BY THE way I Eat, Sleep, Build & research Rotary's for cars and aircraft and raceing
Elevation7
Jun 5, 2002 04:01 AM
Sniper_X
Feb 10, 2002 07:16 PM
peejay
Jan 18, 2002 07:23 AM
vaughnc
Oct 2, 2001 12:31 PM
tonyge
Aug 16, 2001 02:59 AM
