87 NA won't rev up
Old Mar 21, 2010 | 09:00 PM
fatbear's Avatar
87 NA won't rev up
A friend of mine offered to sell me an 87 NA FC but he says it doesn't rev above 2000RPM. Has any heard of this problem or have any tips on what to look at?
Old Mar 22, 2010 | 03:36 PM
The Chazz's Avatar
Sounds like a TPS sensor or something similar
Old Mar 25, 2010 | 06:14 PM
fatbear's Avatar
I finally got some more details from him about the problem and I guess I misunderstood his initial description. This is what he just told me:
It revs up fine in neutral but when it's in gear it doesn't have enough power to drive and it dies. He also says it will die after about 5 minutes of idling.
Is this pattern familiar to anybody?
Old Mar 25, 2010 | 10:52 PM
calpatriot's Avatar
Automatic or manual?
I would start out by first checking for trouble codes. You can make your own code checker for about $3. See...
http://teamfc3s.org/info/articles/errorcodes/main.html
Also, it is possible that you are dealing with an exhaust restriction. You can try pulling the oxygen sensor, and leave the hole open, and then try it. If the symptoms improve, you likely have a clogged catalytic converter or other exhaust restriction.
Try checking the oxygen sensor voltage after the car is warmed up. It should be more than .55 volts (rich). It should stay rich through acceleration. If a vacuum leak is causing the car to die, it would show up as a low (less than .4v) sensor reading under acceleration (lean misfire).
LongDuck
Oct 7, 2015 08:12 PM
Rotafuzz
Sep 30, 2015 09:55 AM
dexter snoek
Sep 29, 2015 09:18 AM
lnlreaper
Sep 27, 2015 09:59 AM
