can anyone help?
Old Mar 15, 2010 | 06:18 AM
etennz's Avatar
TN can anyone help?
Started on my 82 gle 5-speed last week,changed water pump,removed cat and replaced with straight pipe,removed air pump,tried to start and of course it would not,gas flooding and puddling on secondary throttle plates.checking everything,found no spark to bottom plugs,tach has never worked so I Assume it is secondary ignitior bad.Can anyone refer me to a picture or thread that will show me which ignitior controls the lower plugs?Just spent a heart stopping amount for one and want no mistakes installing.Also going to rebuild carb while everything is apart,so any picture guides there would be very helpful.Always,thanks in advance.
Old Mar 15, 2010 | 11:26 AM
Kentetsu's Avatar
For the ignitor question, run a search in the 1st gen tech section.
For carb questions and photos, www.sterlingmetalworks.com
