Looking for FD sway bar suggestions
Old Feb 24, 2010 | 08:17 PM
MeLoN350's Avatar
I have been getting into doing more track days and am wondering if I would benefit from upgraded sway bars. Should I leave them alone, front, rear, or both. Car is a 93 touring, 410 hp, widefoot sway bar mount, JIC FLT-A2's with purple springs (I don't know the spring rate), roll bar, 245/35-18s front, and 285/30-18's rear, super pro bushings. I may pick up a set of R compound tires at some point (after bigger brakes). It would be nice to stay in a reasonable price range if possible, but if a tripoint bar is what is recommended then that is what it will be.
Old Feb 24, 2010 | 09:39 PM
Mahjik's Avatar
Mr. Links
Tanabe is a good starting point for upgraded sway bars.
Old Feb 25, 2010 | 07:50 PM
MeLoN350's Avatar
Any suggestions on the best place to pick up the Tanabe bars? Is it a front and rear set?
Old Feb 25, 2010 | 08:12 PM
Mahjik's Avatar
Mr. Links
Just Google for them as they are available from many places. They have both the front and the rear bars. The place I bought mine from a few years ago is no longer around or I would link you to them.
Old Feb 25, 2010 | 08:34 PM
Scrub's Avatar
bow leggin'
PM Miata_Mx5 (Ganesh) he should be able to point you in the right direction He used to work for SSR/Tanabe
-Dan
Old Feb 26, 2010 | 08:04 AM
MeLoN350's Avatar
I see they are available separatly, do I need them both, or is the 93 rear bar good enough?
Old Feb 26, 2010 | 09:30 AM
Mahjik's Avatar
Mr. Links
I would recommend getting both.
Old Feb 26, 2010 | 12:48 PM
habu2's Avatar
I have Tanabe F/R bars on mine. IMO the car has a little too much rear bar now, I will be swapping the stock rear bar on to compare. The amount of oversteer I have now is good on an autocross course but I haven't tried it on a road course yet.
I would suggest just getting the front bar, drive it then decide if you want/need the rear bar.
If I decide to stay with the stock rear bar I'll sell you my Tanabe rear bar...
edit: I ordered my Tanabe bars from http://www.evasivemotorsports.com/
Old Feb 26, 2010 | 11:33 PM
cosmo105's Avatar
^^^ I completely agree with Habu2's assessment.
I started off with both a Tanabe F/R sway combo and have gone to a RB/stock sway solution for autox (running with 245/45/16 Star Specs on factory rims). I just had too much oversteer I could not adjust for.
Old Mar 2, 2010 | 01:43 AM
muibubbles's Avatar
Bubblicious DEF.
what are your guys inputs on sway bars overall? i use to have an 8 and everyone praises the handling and after i got sway bars for it it made it even better
but i feel like on the 7 not to many people care for them? and theres not a huge difference? please tell me im wrong...
Old Mar 2, 2010 | 08:20 AM
Mahjik's Avatar
Mr. Links
Unless you road race or autox the car, they are "just a mod".
Old Mar 2, 2010 | 05:00 PM
jkstill's Avatar
Searching for 10th's
FWIW I tried Suspension Techniques front and rear.
Way too stiff, especially if the tires were cold on a cool day.
First couple corners in the first run of a morning autox the car simply would not turn.
It was quite embarrassing at one event.
Switched to TriPoint with a .180 bar and the middle position on the arms.
Put the stock bar in the back.
Better, but not good enough.
Changed the TP bar to .125 - even better.
Changed the springs from 550/450 to 700/550 - shocks are Koni Yellows.
Much better, handling is much improved.
Third fastest car at the Northwest Porsche shootout last year.
Unfortunately it was my co-driver that got that time.
Old Mar 2, 2010 | 07:44 PM
muibubbles's Avatar
Bubblicious DEF.
so you guys recommend just the front sway bar? seems like a lot of people like the stock rear sway
Old Mar 3, 2010 | 09:42 PM
jkstill's Avatar
Some folks use the Racing Beat rear bar, which is somewhat stiffer than stock, though I don't know how much stiffer.
It also depends on the climate. Early season autox's in the Pacific NW tend to be on the chilly side - the back end seems to stick a little better for me with the stock bar.
gruss16
Sep 16, 2015 12:13 AM
