Bypass valve question FC3S
Old Feb 22, 2010 | 10:58 PM
SizzFlair's Avatar
Hey guys,
I don't have a RX7.. but i do own a 1995 JDM V2 Subaru STi RA. I've been told that FC3S air bypass valve is a direct replacement of mine.... and it's made out of metal instead of plastic, which would hold boost better.
I was wondering approximately how much psi would it hold (small 16G turbo) with the FC3S factor bypass valve? Next question is where could I purchase one?
Old Feb 22, 2010 | 11:12 PM
RotaryRocket88's Avatar
Top Down, Boost Up
I routinely run 12psi with the stock bypass valve/BOV. I know some have overboosted up to crazier numbers like 20psi, so there apparently wasn't any leaking going on for them to reach those pressures. As for buying, when you have some more posts, the classified section will be available to you. For what it's worth, an FD bypass valve should be just about the same thing too.
Old Feb 22, 2010 | 11:41 PM
SizzFlair's Avatar
Ah okay. So they ARE made in metal correct? And you're saying FC and FD bypass valve are the same?
Old Feb 22, 2010 | 11:48 PM
Top Down, Boost Up
The FC one is metal, but the FD may be plastic now that I think about it. But in functionality, they're basically the same thing.
EDIT: Found a picture of an FD bypass valve, and it is plastic.
Old Feb 23, 2010 | 12:09 AM
SizzFlair's Avatar
Okay. The only reason I'm replacing my bypass valve was I wanted one made out of metal. I figured it wouldn't hurt before I turn up the boost a little bit when I get tuned with new EMS.
I guess I'll just have to rack up the posts so I can start posting on the classifieds.
Thanks for your help. Let me know if you see anyone selling their factory valve
Old Feb 23, 2010 | 10:26 PM
SizzFlair's Avatar
http://cgi.ebay.com/ebaymotors/Mazda...12125011r14088
Just found this baby on ebay... is this a decent price for a used bpv?
Old Feb 25, 2010 | 05:47 PM
Top Down, Boost Up
That's a little overpriced. I've picked one up for $5-10, but it depends on the person.
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Nosferatu
Sep 5, 2015 02:13 PM
